First, download the installation file for your operating system. We recommend having the most current drivers installed for your graphics card(s) and a quick check to see if your computer meets our System Requirements.
You don't need to delete previous versions of SketchUp before installing or updating.
Installation instructions for Windows:
- Open the downloaded Installer file as an Administrator. You may see a security prompt and will need to give SketchUp permission to make changes (install) on your computer.
- When the installation window opens, you'll see a list of products available to install including SketchUp Studio features. Two of these features, Scan Essentials and Revit Importer, are checked by default.
Note: V-Ray for SketchUp requires additional installation steps. If you choose to install V-Ray for SketchUp with the Windows Installer, take a look at our Installing V-Ray for SketchUp article. - To change what language you want to use, click Change... next to Install Languages.
- Click Change... next to the Destination Directory to change where you want to install your SketchUp files.
Tip: While it is possible to choose any location, we recommend keeping SketchUp installed on the C:\ drive.
- Click Install. A window will appear helping you keep track of your installation progress.
- Once you see the "SketchUp 2023 is Ready to Go!" message you can click on the SketchUp icon in the window to launch SketchUp right away. Otherwise, click Finish to close out the installer.
Installationsanleitung für Mac:
Before installing SketchUp, make sure you're logged into your computer as a user who has Administrative privileges.
- Schließen Sie alle vorhandenen Anwendungsversionen von SketchUp, Layout und StyleBuilder.
Tipp: Eventuell sollten Sie auch alle vorhandenen SketchUp-Symbole aus früheren Versionen aus Ihrem Dock entfernen (Rechtsklick auf das Dock-Symbol > Optionen > Aus Dock entfernen), um Verwechslungen zwischen den Versionen zu vermeiden.
- Locate and double-click on the .dmg Installer file. This will mount the installer drive and open a window with a SketchUp icon on it.
- Drag the SketchUp icon and Drop it in the Applications folder to copy the application to your computer.
- Während des Kopiervorgangs sehen Sie einen Fortschrittsbalken. Sobald dieser Prozess abgeschlossen ist, befindet sich ein neuer SketchUp-Ordner im Programmordner.
- To launch SketchUp you'll navigate to the SketchUp folder and Double Click the SketchUp icon.
- The first time you launch the software, you may be prompted with a security message, if so, click Open.
- Close the Installer window and delete the installation disk image drive icon from your desktop by dragging it to the Trash Can.
Installation von Updates
SketchUp Desktop is a client application and therefore needs periodic updates to add new features or to address any bugs or issues. Don't worry, you don't have to watch for those changes, we do it for you!
SketchUp will check with our servers during launch to make sure you're up to date. If there is a new version available you'll see the following notification:
From this notification you can:
- Click What's new? Check out the Release Notes... to review the release notes associated with the update.
- Skip This Version declines the update and avoids any future notifications for that specific version.
- Remind Me Later delays the update. We'll send another notification later.
- Download and Install connects to our server and downloads the latest installer. During the update you can monitor the download process or read the release notes. Once the download is complete click Continue to complete the installation.
Next Steps: Proceed to the Opening and Activating SketchUp article!
