You can create a component whose pricing changes based on the type of material or size of component the user chooses. To implement dynamic pricing in your dynamic component:
- Create a component, such as a cabinet door.
- Context-click on the component. The component's context menu is displayed.
- Select the Dynamic Components > Component Attributes menu item. The Component Attributes dialog box is displayed. Notice that the top-level component is listed.
- Click on the add attribute button in the last row of the component. A drop-down list of attributes appears.
- Click on the Material attribute in the list. The field is populated with the word 'Material' and the field next to the Material attribute is opened for editing.
- Click on the Details button to the right of the Material value. A drop-down list of display rules appears.
- Select Users can select from a list from the 'Display rule' drop-down list. The Display label and a table appear. The following image shows the Display rule drop-down list, Display label field, and table.
- Replace the word
Material
withWood Type
in the 'Display label' field. - Click the Add option icon in the List Option column of the table. A row is created with the field in the List Option column open for edit.
- Type
Cherry
in the 'List Option' field. This text will appear in a drop-down list in the Configure Options dialog box. - Press the Tab key.
- Type
Wood_Cherry_Original
in the 'Value' field. This is the name of a specific material in the Materials Browser. - Press the Tab key to accept the value.
- Plywood, Wood_Plywood_Knots
- Press the Apply button. The attribute details panel closes.
- Click on the Add attribute button in the last row of the component. A drop-down list of attributes appears.
- Type
Cost
and press the Tab key. An attribute named 'Cost' is placed in a list of attributes called 'Custom.' The field next to the Cost attribute is opened for editing. - Type
=if(MATERIAL="Wood_Board_Cork", 40.00, if(MATERIAL="Wood_Cherry_Original",60.50,15.25))
- Press the Tab key to accept the formula. This formula assigns a cost for the door based on the material (wood) that is selected by the user.
- Click on the Close button.
- Select the Component Options menu item. The Component Options dialog box is displayed. The following is an image of the Component Options dialog box for the Television dynamic component:
The following image shows the attribute details panel with all completed fields:
Choosing different Wood Types from the drop-down list not only changes the SketchUp material applied to the component (to reflect the wood type), but changes the MSRP of the door to reflect the wood type.
MSRP =CHOOSE (OPTIONINDEX("MATERIAL"), 40, 60.50, 15.25)
In the previous example, if the first choice in a drop-down list of materials is chosen (Cork), the price $40. If the second choice in a drop-down list of materials is chosen (Cherry), the price is $60.50. And, if the third choice in a drop-down list of materials is chosen (Plywood), the price is $15.25.
