Because your SketchUp models may reside in different places, SketchUp Viewer allows you to access your models from 3D Warehouse, Trimble Connect, and the Files option on your device (third-party cloud storage services). The app enables you to open SketchUp models that are attached to email messages directly from your mail app. And you have the option to transfer files directly to the app via iTunes (iOS only) or by copying a file to the device’s memory via an SD card (Android only).
To review these features and the options that each one offers, open SketchUp Viewer on your mobile device and Sign In. From the app Home screen, tap the Cloud icon () in the top right and select the cloud service you’d like to access.
Table of Contents
3D Warehouse
The SketchUp Viewer app gives you access to many of the same search and browse features you’re accustomed to on 3D Warehouse. When searching 3D Warehouse, you’ll be able to:- Sort (
) models using the following options
- Relevance
- Popularity
- Most Liked
- Title (A-Z)
- Title (Z-A)
- Date (New to Old)
- Date (Old to New)
- Filter (
) results to show models, collections, or both.
- Navigate collection trees using breadcrumb links. As you browse into Collections, you can tap the collection(s) name(s) in the list of “breadcrumbs” in the gray bar above the list of SketchUp models as an easy way to go back up the collection tree.
- Use Prev/Next arrows to navigate back and forth between searches (tablets only).
- View a list of recent search phrases (phones only)
- When you sign in to 3D Warehouse, the Home screen will automatically populate with your public and private models and collections.
- You’ll still need to tap the download button (
) to load a model from 3D Warehouse onto your device.
- When you sign out of 3D Warehouse, any models that haven’t been downloaded to the device will disappear from the Home screen.
- Also note the difference between performing a search from the Home screen, which will return results for only those models that appear on the Home screen, and performing a search from the 3D Warehouse section of the app, which will search all of 3D Warehouse.
Trimble Connect
When browsing Trimble Connect, SketchUp Viewer will automatically filter the contents of your Trimble Connect account to display only folders and *.skp
SketchUp files. To open a folder, simply tap the folder name.
As you browse into folders, you can tap the folder(s) name(s) in the list of breadcrumbs in the gray bar above the list of SketchUp models. This option is an easy way to go back up the folder tree.
As you’re browsing, you’ll have the option to sort or filter using the options listed below:
- Sort (
- Title (A-Z)
- Title (Z-A)
- Recent (Old to New)
- Recent (New to Old)
- Filter (
- Files
- Folders
Once you find the 3D model you’re looking for, you can tap the Download icon () to simply download the file to the Home screen, or tap the placeholder thumbnail (which looks like the SketchUp logo) to open the file viewer.
Files on Device
iOS: SketchUp Viewer directly integrates with the Files app introduced in iOS 11. With this integration, you can browse and open .skp
files stored on supported third-party cloud storage services such as iCloud, Dropbox, etc, from within the SketchUp Viewer app. On the Home screen, tap on the Cloud icon () and select Files on Device. From there, you can select which cloud storage service to browse. Alternatively, you can also browse and open
.skp
files straight from the Files app and choose to open them with SketchUp Viewer.
Android: SketchUp Viewer integrates with Android’s Storage Access Framework. With this integration, you can browse and open .skp
files stored on your device’s local storage and supported cloud storage services from within the SketchUp Viewer app. On the Home Screen, tap the Cloud icon () and select Files on Device to browse the device's Storage Access Framework. Opening a
.skp
file directly from the My Files app is not currently supported.
Opening a SketchUp file attached to an email or on Google Drive
When installed, the SketchUp Viewer app will register itself with your device’s operating system as an app that is intended to be used to open files with the *.skp
file extension. So anytime you’re browsing apps on your device and come across a SketchUp model, whether it’s attached to an email or in a folder of files in your Google Drive app, you can open and view the file.
For files on Google Drive, first tap the *.skp
SketchUp file. Then select the More icon (). Next, select Open In and then SketchUp Viewer.
You can also open *.skp
SketchUp files via your device’s SD card. But this option is only supported on the Android version of SketchUp Viewer.
Transferring SketchUp Files via iTunes
To transfer Sketchup files via iTunes, follow these steps:
- Launch iTunes on your computer.
- Connect your iPad to your computer with the USB dock cable.
- Select your iPad from the Devices list in the iTunes Library column. Then click the Apps tab.
- Scroll to the bottom of the iTunes window to see the File Sharing area. Apps on your iPad that support file transfers appear in the Apps list. Selecting an application’s icon tells iTunes which app you want to transfer files for.
- Click Add at the bottom of the Documents pane to find the documents you want to copy to your iPad.
- Now click Sync to copy the documents to your iPad.
- In your iPad, tap the
*.skp
SketchUp file and choose SketchUp Viewer app from the list.
