Style Builder works with .style
files. Here’s a quick look at how Style Builder enables you to work with these files:
- Create and save a new
.style
file. - Open an existing
.style
file in order to edit sketchy edge strokes and save your changes. - Create a new style based on an existing one by opening the existing style file, saving the file under a new name, and editing the strokes.
In the following sections, you find steps that walk you through creating, opening, and saving .style
files in Style Builder.
Table of Contents
Creating a new file
When you first launch Style Builder, a new file opens automatically, with a Sample Strokes library on the Settings tab.
If you have a .style
file already open and want to create a new file, select File > New from the menu bar, and your new file opens in Style Builder.
Opening an existing file
To open an existing .style
file that you’ve created or that was included with SketchUp, follow these steps:
- Select File > Open from the menu bar. An Open dialog box appears.
- Navigate to the location where the
.style
file you want to open is saved. - Select the file and click Open. Your file opens in Style Builder with a strokes library on the Strokes tab and the Sets pane populated with the file’s strokes.
Saving a file
To save changes to the current file, follow these steps:
- Select File > Save. By default, if your file contains blank strokes or your style doesn’t have a name, you see a warning dialog box. To continue saving your file, click the Save button (Microsoft Windows) or OK (Mac OS X).
- If you’ve already saved your file, then Style Builder saves your style as it appears in the Sets pane, and you’re done. If you haven’t saved your file yet, you see a Save As dialog box. See the next set of steps for details about navigating this dialog box.
To save a new file for the first time or to save changes to an existing file under a new filename, follow these steps, which reflect your current operating system:
- Select File > Save As. The Save As dialog box appears.
- Navigate to the location where you want to save the
.style
file. - (Optional) In the File Name box, type a name for the file. By default, the file name matches the name you entered on the Settings tab.
- Click the Save button, and your file is saved in the location you selected in Step 2.
- (Optional) In the Save As dialog box that appears, click the down arrow next to the Save As box to expand the dialog box.
- (Optional) In the Save As box, type a name for your file. By default, the file name matches the name you entered on the Settings tab.
.style
file. - Click the Save button, and the file is saved to the location you selected in Step 4.
