SketchUp Web Expanded Toolbar
At the bottom of the Main Toolbar you'll see . Choosing that icon opens the Expanded Toolset where you can find the rest of your tools.
When you use a tool from the Expanded Toolset that tool appears in one of the slots at the bottom of the Main Toolbar. You can customize the Main Toolbar to add additional slots.
The Expanded Toolset contains the following tools:
Icon Tool Name Shortcut Learn More
Lasso Shift-Space Selecting Geometry
Sample Material Applying Colors, Photos, Materials, and Textures
Circle C Drawing Basic Shapes
2-Point Arc A Drawing Arcs
Arc Drawing Arcs
Polygon Drawing Basic Shapes
3-Point Arc Drawing Arcs
Pie Drawing Arcs
Freehand Drawing Freehand Shapes
Rotated Rectangle Drawing Basic Shapes
3D Text Adding Text, Labels, and Dimensions to a Model
Offset F Offsetting a Line from Existing Geometry
Follow Me Extruding with Follow Me
Flip Flipping, Mirroring, Rotating and Arrays
Outer Shell Modeling Complex 3D Shapes with the Solid Tools
Intersect Solid Modeling Complex 3D Shapes with the Solid Tools
Union Solid Modeling Complex 3D Shapes with the Solid Tools
Subtract Solid Modeling Complex 3D Shapes with the Solid Tools
Trim Solid Modeling Complex 3D Shapes with the Solid Tools
Split Solid Modeling Complex 3D Shapes with the Solid Tools
Dimension Adding Text, Labels, and Dimensions to a Model
Protractor Measuring Angles and Distances to Model Precisely
Axes Adjusting the Drawing Axes
Text Label Adding Text, Labels, and Dimensions to a Model
Create Section Adding Text, Labels, and Dimensions to a Model
Tag Controlling Visibility with Tags
Zoom Z Viewing a Model
Zoom Extents Ctrl+Shift+E Viewing a Model
Zoom Window Shift + W Viewing a Model
Position Camera Walking through a Model
Look Around Walking through a Model
Walk Walking through a Model
