Downloading SketchUp
Be aware, there is only one installer for all available languages, and it downloads the selected language at the time of installation. After you've downloaded your file below, you'll likely want to read how to Install and Activate SketchUp.
Still using an older version? You can download recent older SketchUp versions here.
If you have a SketchUp Go subscription or you're looking for SketchUp Free you can launch SketchUp For Web here!
Attention: Installing SketchUp 2023 for Windows will require the following system files if they're not already present on the target machine. Don't worry, the SketchUp Installer will attempt to install them if you need them. You must be online for these files to be installed.
Important Note about Graphics Cards and hardware requirements: We recommend having the most current drivers installed for your graphics card(s), and that you check to see if your computer meets our hardware requirements.
How many devices can I authorize with my single-user plan? A single-user license or subscription seat can only be used by the one registered/assigned user, but that user can activate their license or sign-in on 2 computers!
Next Steps: Proceed to the Installing SketchUp article!
Need to install SketchUp on a computer without an Internet connection?
There are two versions of the SketchUp installer, a version which requires an internet connection (links above) and a larger installer which includes all of our supported languages which will allow you to install without an Internet connection.
Need to perform a Silent Installation? Check out our article on how to do it.
